JohnathanPalomares
Today i had to remove one of the clean out plugs from the drain coming from my toilet to remove a block. In the process, i actually removed the fitting from which the plug went into and noticed there was steel wool around the fitting. This is an old style of fitting so none of the parts at my local hardware store has a large enough size or small enough to fit. Im planning to reuse the fitting and wonder if i need to use anything else besides the steel wool to wedge the fitting back in. Thank you.
