Fighting this one for a few days now. Flushed toilet one morning, water backed up and overflowed. Other toilet, shower, kitchen sink, washer all drain fine.
I plunged and found that toilet water was backing up out of the nearby sink.
Ran a 3 ft toilet snake, proved nothing.
Pulled toilet, ran 25ft auger. pulled out some minimal debris. put toilet back on. condition remains.
pulled toilet again, ran 50 ft auger. minimal debris but not nothing. poured maybe half gallon of water direct into the open drain. drain fills up and water stands.condition remains.
I removed the main sewer access in the basement, ran 25ft down. pulled out nothing.
Ran 50ft down drain again. observers auger cable visible through open access port in basement.
poured water in drain. water backed up and no water appeared in open access port in basement.
ran maybe 10-15ft down roof vent. Hit a bend i could not get by.
Pulled sink. ran backwards shop vac into sink drain pipe. Toilet drain bubbled a bit but did not shoot out or anything to suggest considerable air pressure.
Ran 25ft through sink drain pipe. found no debris.
Anyone have any ideas what is going on here? Im struggling to understand how the drain auger can traverse the piping and pop out down stairs, but not a drop of water follows that same path.
