Can I use a Brass Dresser tee on galvanized pipe? Seems only the gasket makes contact to both metals.I have used 1000's of dressers as long as the pipe is restrained they will last a long time
of course. the ''correct'' fix would be to remove the galvi pipe and replace with new pipe
i do believe that a dresser tee [middle threaded] can be found on a goggle search.
note.. do not use a pvc dresser only use a gavli dresser
a dresser is a repair fitting. and the correct position of the fitting is in a pipe run that does not move
it can not be used on a end of the line
Hi Doc, The hot pipe closest to to drain on left is supply coming from crawl space under house. Feeds up to sink above. The sink and surrounding tile are 1930's vintage so irreplaceable. I was trying to avoid having to demo the kitchen sink. I think i have a solution as to feed 2 separate copper pipes (in-line) up to sink and connect half way with hot valve in center. That way i don't have to demo the outside wall as one contractor suggested. Jeff advised me to use brass at thread connects from source galvanized pipe. Space is tight in this old construction. Cabinets were the last thing added in those days.
