uthorns1976
Today, my brother and I replaced my pull down diverter tub spout because it had failed and I lost pressure to the shower head. I got a new Delta RP17453 Tub Spout online. We removed the old tub spout that had failed. The tub spout comes with a brass adapter. That brass adapter was already on the copper pipe coming out of the wall. the brass adapter has an O ring at the end. We replaced the old O ring with the new one that came with the tub spout. So far so good. Now, here is my concern. The back end of the brass adapter has threads that the tub spout threads, which are either plastic or nylon, thread onto. Those threads are basically for the tub spout to screw onto. We applied Teflon tape and a little soft set pipe dope to the threads prior to screwing the new tub spout on. I see now that doing that is not really necessary. Ugghhh. My question is was putting the Teflon tape and pipe thread sealant on those threads a fatal mistake? Will doing so cause a leak? Based on what I have read, the O ring at the end of the adapter is to prevent leaks. The water comes out of the copper pipe that goes through the middle of the brass adapter. Where the tub spout screws onto the adapter does not need to be water tight.
So, my bottom line question is did we foul up the install of the new tub spout by putting Teflon tape and a little pipe sealant on the threads on the brass adapter that the tub spout screws onto??? Is that going to be an issue? I do not think so but wanted to get input from those who know way more than me.
This is a picture of the adapter in question. You can see the threads in question at the back end of the adapter.
Many thanks for reading my post.
