John, I didnt mention a CSV on the Water Cannon thread. I was trying to show how to make a good water cannon using linear flow.
But since you mentioned it, I will explain the difference between a CSV and a Pressure Reducing Valve or PRV. A PRV is a fully closing valve that will deadhead and burn up your pump is just a couple of minutes. If you drill a hole through the seat of a PRV, you can make what my so-called competitors claim is just like a CSV. However, the drilled hole needs to be less than 1/16th of an inch to produce a minimum flow of 1 GPM. A hole that small will quickly clog with mineral deposits, the same way the holes in your shower head clog. Water jetting through any size hole will cause the minerals to precipitate out and clog the hole. When the hole clogs, your pump will be destroyed from a lack of cooling flow in just a couple of minutes. To slow down the time it takes to clog the hole, my so-called competitors will drill a 1/8 or larger hole. Now you have about a 3 GPM minimum through the PRV, which will cause the pump to cycle on and off when running a 2.5 GPM shower or a sprinkler. Plus the pressure tank needs to be three times as large for a 3 GPM minimum as it does when you have a 1 GPM minimum.
In 1992 we tried for several months to figure out a way to keep a hole from clogging. We tried different sizes, shapes, and placements of the hole to no avail. We tried screens, filters, and even wipers and spinning wires in the holes to try to keep it from clogging. No matter what you do a drilled hole will always clog. Then we discovered the trick that makes the CSV dependable. We made a half moon shape notch on the moving part of the valve and another on the seat. When the valve closes, the two half moons come together to form a small hole that produces the 1 GPM minimum we needed. Since the valve is pressure operated, anytime something clogs the small bypass, the valve opens, splitting the hole apart, and allowing the debris to flush away.
We also experimented with round notches, square notches, multiple notches, and different placements for the notch. The notch not only solved the problem of clogging the bypass, but also eliminated water hammer and pressure spikes that happen when you close or open a valve against pressure. To try and prevent pressure spikes, a PRV is made to open and close slowly. Slowing the valves speed causes even more problems when the flow rate changes in the field, and the pump control valve cannot function as fast as needed.
It was a real eureka moment when we finally figured it out. The CSV cannot clog, and we were able to increase the valve travel speed many times faster than a PRV. Over the years we have had hundreds of thousands of installations to test and prove the CSV itself has no fatal flaws. It really does makes pumps last longer, use smaller pressure tanks, eliminates water hammer, pressure spikes, and most other problems associated with pump systems.
This makes the CSV just as disruptive to the pump industry as the automobile was to the horse and buggy industry. So you have several groups trying to discredit the CSV for different reasons. Pump manufacturers, suppliers, and related businesses try to discredit the CSV to keep homeowners pumps from lasting longer than the expected, and designed fail date. Notice that NO pump manufacturer promotes the CSV, and many lie about it being bad for your pump. Pump manufacturers promote big pressure tanks, Variable Speed Pumps or VFDs, and tankless widgets with flow switches and flashing lights that shorten the life of your pump, to get as much of your money as they can. You dont really expect the horse and buggy manufacturers to say anything good about the automobile do you?
Most pump installers are good people, but very naïve. They still try to do the best job possible for their customers, and dont believe their manufacturers would outright lie to them about their products. Yeah right! I hear from installers everyday who have found out the hard way, how much pump and tank manufacturers really care about them. ZERO!
Then there are engineers who have a home pump system, and people who install a few dozen pumps a year, that think they know more about it than others with hundreds of thousands of installations under their belt. They will gang together on chat rooms and forums and tell people the CSV is snake oil, because they have no idea what they are talking about.
I get falsely accused of not really wanting to help homeowners, because everything I post anywhere is about the CSV. That is because decades of experience and hundreds of thousands of installations have proven to me that cycling is the number one cause of most pump system problems. Everything from a burned motor to wire chaffing is caused by cycling. Noise or split fittings from water hammer, pumps coming unscrewed, tank bladders bursting, pressure switch points burned, check valves failing, sediment in the water, fluctuating pressure, low pressure, and many other problems can be attributed to cycling. When you stop the pump from cycling on and off, 99% of your problems go away. That is why the CSV is so disruptive to the industry, and why so many people will try to dissuade you from using one.
Sorry for the long post. The CSV is a very simple product with a long and complicated explanation. It doesnt help when others try to further complicate the issue with their lack of understanding, or outright deliberate attempts to keep the homeowner from extending the life of their pump system.
