Nukedaddy
Those who have read my postings know that I often ask about newer products that were not in use when I was still “on the tools”.
This is one.
For CSST gas tubing systems, are the various brands of fittings interchangeable? Is the tubing itself made to an ASTM standard regardless of brand?
Or must I pick a brand of tubing and match the fittings to one manufacturer?
Also… It appears to me that very few brands make tees to go on the corrugated tubing. Might that be that manufacturers chose to support an iron header just in from the meter and then “home-run” each service branch individually?
I want to add a gas range service to my home. I have a 3/4 CSST line to my furnace and a 1/2 CSST line to a gas fireplace, another 1/2 to the water heater.
I would find it easy to cut a tee into the 3/4 serving the furnace to serve the gas range, but a 3/4 x 3/4 x 3/4 CSST compression tee is difficult to find.
Possible, but mort complicated will be to back up to the meter area and put in another iron tee for a 3/4 home-run for the stove.
Suggestions? Opinions?
This is one.
