theotherklingon
I'm in a bit of a pickle with a cracked copper pipe on an outdoor water spigot. The copper pipe that passes through the exterior wall into the basement cracked due to freezing. I've done some research for how to replace it, but most of the help assumes a copper:copper connection, rather than a PEX:copper connection.
So, I'm wondering how I might go about replacing this cracked spigot that connects to a PEX water line that was professionally installed by the builder?
I attached a photo, which shows that a fitting was soldered to the spigot, then inserted into the PEX waterline. Is there any way to fix this without having to redo the PEX/fitting connection?
Any help would be greatly appreciated!
