AJay
Moron
Got to repipe the hot and cold supply for "The Great Bathroom Adventure" and while I was going to replace the copper with copper, I'm not so sure.
Have found enough pinhole leaks in basement to realize it should all be replaced. But a lot of existing piping is perpendicular to joists, there are lots of short pieces sweated together.
I have done enough soldering to have the notion I know what I am doing but most of the connectors are up against the ceiling of room below and can see it would be easy to end up with a few bad connections not being able to see all around the pipe. (tho I do have a little mirror that is helpful).
Also copper is expensive. So am considering PVC for cold water and CPVC for hot. I live in Maryland, which doesn't get tremendously cold, tho copper can burst too if Pepco stops feeds us electricity for extends periods after a winter storm. (That's a big problem in the People's Republic of Montgomery County, where the tree hugging enviro sickos won't let them trim trees near power lines.)
Any comments.. or tips if I do chose the PVC route?
AJ
AJ
