Condensate pump not shutting off.
Discussion in 'Pumps and Wells' started by Douglas Leach, Dec 31, 2018.
  1. Dec 31, 2018 #1
    Douglas Leach
    Douglas Leach
    Douglas Leach
    Dec 31, 2018
    7
    South Lyon
    Ok my condensate pump, well what I think it is, won't shut off. Stuck float? Maybe, it will turn off with a tap. My real concern is why it's turning on. Only the AC and dehumidifier are Hooked to it and it's winter. Now it turns on when you use the shower or run water, why? I feel that I can replace the pump but there is another problem here. Help please.
  2. Dec 31, 2018 #2
    Geofd
    Geofd
    Geofd
    Professional Professional
    Jan 20, 2018
    803
    122
    Boston, Massachusetts
    can you show us pics of what your talking about????
  3. Dec 31, 2018 #3
    Douglas Leach
    Douglas Leach
    Douglas Leach
    Dec 31, 2018
    7
    South Lyon
    This is the pump that turns on with running water especially the shower. The black line is from dehumidifier and the clear line in the back is from furnace. And the PVC pipe leads to drainage pipe.
  4. Dec 31, 2018 #4
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    803
    122
    1not sure why its sticking maybe a switch maybe dirty????may be vac it out soak it in vinegar for a bit
    2have someone run the water if you see water draining back thru your pipe from the main drain
    3 that pvc should be a little higher that your main drain so it can go by gravity
    there should be a check check valve there also so it doesn't drain back and short cycle
  5. Dec 31, 2018 #5
    Douglas Leach
    Douglas Leach
    Douglas Leach
    Dec 31, 2018
    7
    South Lyon
    I'll take it down and try cleaning it. I will also install a check valve. Is it normal for this pump to come on during normal running water operation?
  6. Dec 31, 2018 #6
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    803
    122
    tough to see but your condensate and humidifier should be draining in one place and your main drain pumping out in another
  7. Dec 31, 2018 #7
    Douglas Leach
    Douglas Leach
    Douglas Leach
    Dec 31, 2018
    7
    South Lyon
    Nope. The previous home owner just tied the dehumidifier and furnace drain into a Y pipe into main drain. I bought a mess of a house. I won't get started lol.
  8. Dec 31, 2018 #8
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    803
    122
    if only those two things are draining into it then no.....you may have a partial stoppage and the water is backing up and draining back enough to turn your pump on you should run the water and physically see if water is coming out of that pipe
  9. Dec 31, 2018 #9
    Douglas Leach
    Douglas Leach
    Douglas Leach
    Dec 31, 2018
    7
    South Lyon
    So remove pump and run water?
  10. Dec 31, 2018 #10
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    803
    122
    no run some water and see if its draining into your pump from the white pipe run hot water so you can feel temp change
    jeffmattero76 likes this.
  11. Dec 31, 2018 #11
    Douglas Leach
    Douglas Leach
    Douglas Leach
    Dec 31, 2018
    7
    South Lyon
    Ok ill will give it a whirl. Thank you. I'll reply results.
  12. Dec 31, 2018 #12
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    803
    122
    good luck
  13. Jan 1, 2019 #13
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    803
    122
    this really should be draining into a properly vented and trapped fixture....
  14. Jan 1, 2019 #14
    Douglas Leach
    Douglas Leach
    Douglas Leach
    Dec 31, 2018
    7
    South Lyon
    Yea I'm having work done this summer under the house so I'll add this to that list. I ran some emergency septic flush stuff and it hasn't come back on yet. Scheduling a septic appointment asap. Thank you for all your help.
  15. Jan 1, 2019 #15
    Geofd
    Geofd
    Geofd
    Jan 20, 2018
    803
    122
    good luck with everything!!!!!!!
  16. Jan 2, 2019 #16
    CT18
    CT18
    CT18
    Apr 30, 2014
    410
    93
    Bloomfield Hills, Michigan
    Its winter, do you have a humidifier running right now.
  17. Jan 10, 2019 #17
    frodo
    frodo
    frodo
    Sep 28, 2014
    6,583
    2,075
    you need a check valve to keep sewage from backing up into the pump
Share This Page
