Cistern inlet.
Discussion in 'Toilets and Sinks' started by qprdude, Dec 1, 2019.
  1. Dec 1, 2019 #1
    qprdude
    qprdude
    qprdude
    Jan 29, 2017
    I have a concealed cistern with plastic fitting through the sid. From the plastic, there is a steel flexi pipe across the top of the Dudley dual flush, with a half turn valve and loose running nut connecting to the float valve assembly. The half turn ball valve is leaking (throught the centre not the fittings threads) at the opposite side from the actuating slot. If left fully open, it sprays out, so I assume the valve seal/seat is knackered. The cistern fills and the overflow back to the toilet bowl is continuously running. Is the flexi/ valve, a standard off the shelf part. Cheers.
  2. Dec 1, 2019 #2
    qprdude
    qprdude
    qprdude
    Jan 29, 2017
  3. Dec 1, 2019 #3
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    680
    95
    Chicago suburbs
    Does not look familiar at all.
    Most members here are in North America.
    Where are you, UK?
  4. Dec 1, 2019 #4
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,124
    358
    North Reading, Mass.
    I'm guessing you're located outside the USA.
    That flexible hose apparently comes with that factory assembled 1/4 turn valve.
    I think you'll have to find a replacement for that assembly locally.
  5. Dec 1, 2019 #5
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,124
    358
    You beat me by a split second.
Share This Page
