I'd love some help! My plumber installed a back to wall cistern to my super tiny bathroom as per below. He was supposed to put the flush handle on the right hand side where there was more space. Instead he put it on the left, it sits behind the toilet lid, which means you can't put the toilet seat up properly. He is now telling me that this is the only way he can do it. However, it doesn't quite make sense to me, especially given the fact that the way he has done it, when you pull the flush, the plastic lever in the cistern seems to be bumping on the blue plastic bit on the side that connect to the water pipe.
So my question is: can you turn the cistern around, so the water pipe is connected to the back right with ballon thingy being on the left, and then happily put the flush handle on the front right? It would be on the side I need it and nothing would be bumping on anything.
Thanks so much for your help.
https://photos.app.goo.gl/KVTRck4xfGyjcO4U2
