I recently had new Delta shower/tub hardware installed. The showerhead is a hand-held model. There are 2 check valves in series in the showerhead handle (as well as a screen and a flow-reducing orifice).
My question is: Why are two check valves (or even one) needed in the showerhead? Delta tech told me that in some areas, the check valves are required by law. There's certainly no backflow to worry about, because there's nowhere for the backflow to come from. Is this just another way (in addition to the orifice) to restrict water flow?
I know I can remove the check valves and orifice, so I'm just trying to determine if there's a technical reason not to.
Thanks for any info you can provide.
