I have a check valve located on the input water line from my shallow sand point well. It is located in the cabin right next to the pump, the well is outside in my shed. I find drawings where sand point installations have a foot valve. Do I assume that a check valve implies no foot valve?
I am asking because I am winterizing and do not understand if i need to worry about the water remaining in the line between the check valve and the shed? Will gravity return the water in the line back to the well? Or if there is a foot valve will that hold the water in the line between the cabin and the shed.
The line is underground and goes straight down into the earth inside my cabin.
Thanks!
Thanks!
