paqmanbiker
Hey everybody, new guy here. Just need some advice from the pros. So I'm redoing the flooring in my house, so I have to take up my toilets in the process. When I took up the first toilet, I noticed the metal flange ring was pretty badly rusted. So bad I had to drill out one of two of the screws because they just fell apart. So I need to replace the flange. But I'm not sure how to replace the old abs flange. I haven't completely cut it off down to the floor yet, but it looks like maybe it is going on the outside of the main pipe, but not sure. The inner diameter of the pipe is 3 inches. If I just lop off the flange level with the subfloor, can I just get a flange that will fit inside that 3 inch pipe and glue that in? Or do I need to somehow cut off the old flange off the outside of the pipe? (assuming that it is on the outside) Can I go ahead and cut the old flange level to the subfloor now to get a better idea of what I'm working with? I've replaced a toilet before, but have not had to replace the flange, and want to make sure I don't screw anything up that will cause me more costly repairs.
This flange looks like it will fit inside a 3 inch pipe. Can I just cut off the current one and cement this one in?
https://www.lowes.com/pd/Oatey-PVC-Flange/50315065
Thanks for any help or advice. Here are some pics of what I'm dealing with.
