Installed a new submersible pump and then discovered why it died, turns out I had a break in line outside of well casing at the pitless adapter.
Dug down 5ft, by hand, and installed a compression fitting. Now I need to backfill this hole.
Can I use pea gravel? Someday it will need to be dug out again and I think it would be MUCH easier if 2/3 of it was gravel.
Thoughts please.....
Than
Than
