Hi Folks;
I'm hoping that someone can help me out. I'm having some issue with be Febco 825Y (3/4") leaking from behind the relief valve. I've been troubleshooting it for a while and I'm stumped. Here's what the leak looks like.
So a bit of history.
- I'm not the original owner and it looks like the backflow valve was installed upside down. That will need to be addressed once this problem is solved.
- I went to pressurize it a couple weeks back and noticed the relieve valve was cracked. Probably from being upside down through the winter. (Bad one is on left, replacement on the right.)
- I ordered a new relief valve and a complete replacement gasket set. Skipped the discharge shield for now.
- I completely disassembled the unit, checked for debris and found a couple pieces that I removed.
- While the relief valve plate was removed, I used pressurized air to clean out the 2 small channels. I don't know the proper name but they are what the 2 plastic tubes connect with in this shot. I believe they pressurize the relief valve.
- Replaced every gasket and the relieve vale.
- The check valves were not cracked and the springs were not corroded so I didn't replace them. I did replace the rubber gaskets.
- Disassembled the replacement relief valve to check the o-ring (just in case) It was good.
- Reassembled the unit and slowly pressurized.
- When I pressurize the system, you can see the relief valve closes but I still get water flowing from behind it.
I don't have a pressure gauge so the only way I can check if the first check valve is operating is to open test cock 4. Although, the relief valve is closing so I suspect that the text valve is OK. For completeness, you can see what happens when the test cock is open.
Any thoughts would be greatly appreciated!
