Burst pipes
JG plumbing
Mar 26, 2021
617
154
Iowa
I think he used the tape as a buffer between the coupling (I'm guessing he sweat a coupling in) and the steel strap. Not a bad move. Not the greatest but nothing wrong with it.
breplum
Professional
Professional
Nov 14, 2017
940
420
Lafayette, CA
Jeff Handy
Jul 5, 2019
4,019
1,156
Chicago suburbs
Pipe insulation is going to make it more likely to freeze.
The pipe needs to be exposed to conditioned air to stay warm.
If the area is totally unheated, even by casual heat leaking into there, then that whole line needs to be drained and blown dry from late fall to spring.
Twowaxhack
Professional
Professional
Feb 9, 2021
2,260
861
United states
First time I’ve ever heard anyone claim that insulating a pipe will make it more likely to freeze.
Could it be true ?????????🤣
Twowaxhack
Professional
Professional
Feb 9, 2021
2,260
861
United states
Insulation prevents the pipe from gaining ambient heat from the surrounding space.
Then it would also keep it from losing heat.
If the space had heat, it wouldn’t freeze.
It’s common knowledge that insulation slows the freezing process but doesn’t stop it.
Advising not to insulate a pipe because it will make it more likely to freeze is a ridiculous statement.
Sorry buddy.
Jeff Handy
Jul 5, 2019
4,019
1,156
Chicago suburbs
It is losing heat into the portion of the pipe that is outside.
Insulation is not heat tape.
I have run into this many times, with pipes feeding sillcocks, or sump pump discharge lines.
Well-meaning homeowners or plumbers insulate the pipe near the exit out of the house, which prevents basement or crawlspace heat from getting to it.
So the pipe freezes.
Jeff Handy
Jul 5, 2019
4,019
1,156
Chicago suburbs
You have been vocal many times about codes not always based on real life.
So don’t use them as your proof.
You are wrong on this one, but be as stubborn as you want, no biggie for me.
JG plumbing
Mar 26, 2021
617
154
Iowa
I'm I just gonna say that this is highly dependant on circumstances. But the code is to insulate.
Insulation does need to be thought out.
Twowaxhack
Professional
Professional
Feb 9, 2021
2,260
861
United states
If the space is subject to freeze then the correct course of action is to insulate.
That’s not debatable with me.
You either have to insulate or not. You can’t take it on and off across the whole crawlspace depending on ambient temp at the moment.
This is getting ridiculous.....
