Burn pipe to fit
Discussion in 'General Plumbing Help' started by locknut, Jan 26, 2019.
  1. Jan 26, 2019 #1
    locknut
    locknut
    locknut
    Jan 26, 2019
    Knoxville
    Having a stand alone condo built, on a concrete slab. The plumber heated this pipe (see picture) to bend and twist to make it fit because it was coming out of the concrete in the wrong position. This is in the master bath that has 2 sinks and this is the drain for one of the sinks. The contractor says it has to stay that way because its toward the out side wall and they would have to cut into the concrtete floor and foundation to fix it. He said a pressure test was done and if I want he will do it again. As you can see in the picture its very close to the concrete slab and the plumber heated it with a torch to position it. The county inspector has ok'ed it.
    1. Should I accept it ?
    2. Put bore scope in pipe and see what it looks like inside?
    3. Come out of this sinks drain pipe over to the other sinks drain pipe as a back up in case the drain cloges with hair and etc. in the future?
    4. What is your thoughts?
    Thanks
    Ron
  2. Jan 26, 2019 #2
    journeyman
    journeyman
    journeyman
    the professional
    Oct 4, 2012
    538
    165
    san diego, california
    Wtf an inspector passed that they need to come and do it right to fix it that is total BS work
    phishfood likes this.
  3. Jan 26, 2019 #3
    Mr_David
    Mr_David
    Mr_David
    Easily Amused Professional
    Jan 12, 2010
    4,171
    1,058
    Santee,Ca,
    I agree. That's Bull crapp! That pipe coming out of stab looks like it's in the wall to me. What's the finish wall ? Stucco?
    What building code are you under. I'm sure there something That says you can't do that.
    Building Inspectors ARE NOT QUALITY CONTROL. They don't always see every thing.
    I'm sure if you pointed that out to the Inspector, he just might have different thoughts about approval.
  4. Jan 26, 2019 #4
    journeyman
    journeyman
    journeyman
    the professional
    Oct 4, 2012
    538
    165
    I dont know an inspector around that would pass that unless he just does not care. Ultimately it falls back on plumber who installed it anyway but I would fire that jack ass
  5. Jan 26, 2019 #5
    Tnkrst
    Tnkrst
    Tnkrst
    Jan 13, 2019
    23
    6
    Centennial, Colorado
    Lol was that really an inspector that passed it or a friend?
  6. Jan 26, 2019 #6
    Tnkrst
    Tnkrst
    Tnkrst
    Jan 13, 2019
    23
    6
    I also don’t know how any poo or tissues gonna flow down that. That’s a back up waiting to happen
  7. Jan 26, 2019 #7
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,761
    2,408
    no way in hell wound i accept that bullchit
    call this guy at the building department, ask for the head plumbing inspector
    send him that picture in an email tell him you need a inspection because you
    believe this was done after the inspection.
  8. Jan 26, 2019 #8
    Matt30
    Matt30
    Matt30
    Professional Professional
    Jan 17, 2012
    2,142
    827
    Halifax, Nova Scotia
    I’m not sure how any competent individual would perform that work, or pass it off as good.
  9. Jan 26, 2019 #9
    mike fiore
    mike fiore
    mike fiore
    Aug 18, 2018
    120
    28
    exeter rhode Island
    that's horrible..it looks like pvc . just cut below burn and glue pvc coupling with new fitting and use slip coupling or fernco above.
  10. Jan 27, 2019 #10
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,761
    2,408
  11. Jan 27, 2019 #11
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    979
    211
    Mansfield,, Ohio
    What ever happened to 45 degree fittings or less. I've only been retired a couple years now and I do think you can still
    get them. LOL.....
    frodo likes this.
  12. Jan 27, 2019 #12
    wood4d
    wood4d
    wood4d
    Apr 1, 2014
    149
    29
    absolutely no good. Do not accept that, Let them cut the concrete if that's the best they can do
  13. Jan 28, 2019 #13
    CT18
    CT18
    CT18
    Apr 30, 2014
    553
    136
    Bloomfield Hills, Michigan
    That is a reduction in direction of flow and is not legal. I cant believe the inspector saw that and let it go. It doesnt matter if it held air the ID of the pipe is not the same in that spot.
  14. Jan 30, 2019 #14
    phishfood
    phishfood
    phishfood
    Moderator Staff Member Professional Supporting Member
    Jan 18, 2010
    5,775
    992
    Orlando, FL
    What everyone else said.
Draft saved Draft deleted
Share This Page
