Jamesplumbing06
Ok so I arrived at a house today. They have a moen. It has been installed for 1 week. Issue is that water dribbles out of shower head while only wanting tub spout to be running. Copper thru out house. First guy plumbed tub spout with crimp pex and pex elbow like you would with copper. So immediately I noticed tub spout spins in a circle. Crimp restricts flow. I have had this happen before. So I went to truck and removed the female fitting to valve and used expansion pex with an eared ell. Mounted eared ell in place and installed new make x male copper tube going into tub spout. Done this maybe a hundred times. Still did the same. Didn’t have copper eared ell so I used a shark eared ell and shark female to attach to valve. SAME THING. I know I am looking over something simple and it’s hust been a long week. Psi is at 85 no regulator. But the expansion eared ell has big enough to work at 98 psi on a house just last month. So somebody pitch me a few things. Valve is installed with square part of valve up. So it’s oriented correct. Unless that last dumby turned the clip upside down so the trim would match picture. But I going back Monday. Nobody living there and I need to think. Does it without spout on
