I can help you out with that. The Cycle Stop Valve was designed to replace variable speed pumps or VFD's and uses a regular pressure tank/pressure switch to turn the pump on and off. Once the pump comes on the completely mechanical Cycle Stop Valve can be adjusted to hold from15 to 150 PSI constant as needed. In your case, that pump can only do 24 GPM at 60 PSI. You need a larger pump as you know you are losing 40 PSI through the filters and only getting 10 PSI out. If you need 20 PSI more out, you will need at least 20 PSI more coming in. I am not certain of your application, but it sounds like you need a pump that can do 37 GPM at 80 PSI. 37 GPM is 25 for the backwash and 13 for the RO if they run at the same time.
Setting a Cycle Stop Valve model CSV3A2T at 80 PSI constant will vary the flow rate from as little as 3 GPM to as much as the pump can produce while maintaining the 80 PSI constant at the CSV. A standard 70/90 pressure switch with about an 86 gallon size pressure tank will work with the CSV3A2T to automatically turn the pump on or off when needed, and the CSV will hold 80 PSI constant while water is being used. The CR series pump has a very good drop in horsepower when the pump is running at full speed and simply being restricted by a CSV. The drop in HP is very similar to the drop in HP when the speed is reduced using a VFD. But nobody wants you to know that, or people would not be interested in a VFD to start with.
I spent some time on the Grundfos web page this morning and cannot find a curve for a pump without the "integrated variable speed". I am sure there is such a pump, in maybe the CR10-7 size or so. But they want you to use a VFD so bad they "integrate" them onto the motor so you don't have any choice. A VFD makes pumps much more expensive and short lived, which is the main reason pump companies push them so hard. But many people wrongly believe a VFD saves energy, which makes it easy to sell an expensive and short lived pump.
Here is a little drawing of how to install a CSV on an end suction centrifugal, and another with 4 vertical pumps on a pump station.
