slickrock22
Over the last few years in Austin Texas we have had freezing weather and I have had a few exterior pipes break int winter. I would like to add some shutoff valves in the garage where the city waters enters the house. I have found the termination point near the water softener. There are 4 hard water pipes that feed the exterior hose bibs of the main before the softener. Ideally there would be one shutoff valve but I think it would be easier to add 4 on each copper line vs rebuilding the entire branch off of the main. I was thinking about using PEX becuase the copper looks like it needed to be bent/forced into the current configuration and I might have some difficulty getting copper to fit proerly. I was thinking that I could use a copper to PEX soldered connector on the copper coming up from the floor (goes to outdoor hose bibs) and down from the branch off the main. I would then create a PEX line with a ball valve in the middle of each of the 4 pex lines. Does this seem like a good way to do this? Any advice is greatly appreciated. I think I will need some type of door to access each winter and spring.
