Ben Keller
The pipe I am showing a picture of is leaking from the places where it is joined together. How hard is this to fix? can a novice do it? how do I disconnect the copper line at the top from the pvc pipe? Is there a reason the pipe is spliced 3 different times? How do I separate the splices? I will need to put the new pipe into lower section of the old pipe,so I need to keep it intact and not cut it. Reason for that is because there is a crawl space under the house and I can't fit into it so the repairs will have to be made from the top. Please be specific about parts and supplies needed,I will be working 20 miles from the closest store. Thanks for the help!!
