squeekee35
We have been living in this house now for 2 years. it's an older home....i don't know how old. but the bathtub is very slow draining....by the time you are done with a shower the water is about to your ankles, or deeper depending on how long you are in the shower.
at any rate it keeps clogging up. we use draino on it and that seems to help usually. but this last time 3 applications of draino did not work. i suspect it has a drum style trap and that it needs to be cleaned out. the problem is the trap is not accesable. it's either under the tub or under the tile on the floor.
is there anything that can clean out the drum, like stuff you put in your sewage tank or some othe kind of home remidy that can eat away all the gung in the trap?
we are going to snake it tonite to see if that helps, but if the trap has build up in it like i suspect i don't think snaking it is going to do any good.
thanx
--Angel
thanx
--Angel
