That's a pretty tricky thing to hook up.
It is probably soldered in.
You have to set up the drain and overflow so when you set the tub into place it lines up perfectly so you can screw in the drain and the over flow.
This is one that you should hire someone that knows how to do it properly.
Good Luck
