slagathor
Hello, so since I bought my house my sink in the bathroom has had clogging issues. It was one of the first things I had to attend to after moving in. Extremely slow drainage that would take an hour to go below the sinkline. I bought a drain auger, took it apart, and cleaned what looked like a bunch of mostly biodissolved hair out of it. Put it back together, and it drained beautifully for 6 months. At which point it started getting clogged again.
So i took it apart again, cleaned it, and everything was fine again for about another 6ish months. It started draining slowly again recently, and I just accepted that this was going to be part of my routine maintenance. However, this time, after cleaning it and putting it back together. I can't stop getting it to leak at the wall.
When I run the faucet, everything will run perfectly for about 10-15 seconds. After which water will start dripping very fast right at the junction of the pipe that goes into the wall (should be clear in the attached pictures). It's almost as if the water gets backed up then is being forced back at me. When I take it apart there is quite a bit of standing water that I can see.
I figured I didn't clean it well enough... but even if that were the case it absolutely shouldn't be leaking if the drain is just clogged somewhere in the line? I replaced all parts that I could, including slip washers, and the same issue occurs. Is there anything I can do about this?
Thank you in advance for any advice!
