Bathroom shut off valve
Mustangsallie
Jun 27, 2020
Oregon
So Water stopped coming out of the faucett- at first the valv3 was stuck, I could hear gravel crunching as I turn3d i5 back and forth- I figure there must be gravel stuck- so how do I get the valve off this plastic pipe ? The white plastic at th3 end just turns -pictisof kitchen sink area but they’re the same thru out the house.
breplum
Professional
Professional
Nov 14, 2017
456
156
Lafayette, CA
It looks like expansion/PEX. Oh so stupid! Pathetic. And multi- turn angle stop to top it off. Oh my, what dirt-bag cheap work. It this a tract of some kind?
Turn whole house off, drain, remove the stem from the angle stop. Mitigate what ever is inside causing the problem, and re-install the stem.
Better but bigger solution is to open the wall and have a plumber install copper tube stub outs.
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
1,932
279
Boston, Massachusetts
What is the brand name on the valve,usually they can be rebuilt with 2 washers
Mustangsallie
Jun 27, 2020
Oregon
It’s a Hayden home- builder here in Oregon. Every valve in the house is this way. Guess I’ll be calling a plumber🤪
Pat the Plumber CIL
Professional
Professional
Apr 23, 2020
62
37
Springfield , Il
Yes expandable pex . Not enough pipe sticking out of the wall to replace valve without cutting drywall . Like Breplum posted turn water off . Remove stem and handle . Clean any debris out of valve body . You should be able to find same valve at hardware store . Remove new stem and install in existing valve body . Should be ready to go .
