The outside temp in NY at the moment is 38 degrees. I woke to an apartment that was ~ 71 degrees. But with each hour, I have lost heat. At the moment (11:30am) the apt temp is 62 degrees. This is the daily pattern. Since I began the thread, I have surfed through a bunch of blogs and looked at videos that deal with the Navien NCB-240E. (Ours was installed in 2017.)
As initially stated, I became convinced that somewhere in the system, a ‘schedule’ was triggering my daily heat drop. The appliance itself is essentially ‘closed’. The front panel does have a small led screen that allows for basic interaction – but no real access. However, Navien now produces a Navilink device - I assume it could be used by our model. In the Navilink product video, around the 8:30 mark, they discuss ‘recirculation’ – that was the closest thing I could find to a schedule:
I’m a layman, but it sounds like the function of ‘recirculation’ is to make sure the temps in the lines remain at predetermined levels. Not sure if that is true but in theory it might an impact on my heat. The video mentions other ‘parameter’ settings available via the Navilink but it doesn’t explore. Moreover, it ‘seems’ that the focus all seems to be on “domestic hot water” and not space heating (baseboards) which is my issue. I never seem to lose hot water in my taps.
So here I am a bit more knowledgeable but still cold. I don’t want to move. The landlord isn’t taking short cuts, he just hasn’t gotten the help from the local ‘pros’! But he’ll likely just call them again when I broach the subject. So what do you think:
1. Can a Navien rep be brought in directly for a review? If so, should I suggest?
2. Should I also suggest installing a Navilink? The video suggests the installation is plug and play?
PS. Mark's theory about the restaurant next door siphoning my heat still needs to be officially ruled out.
That’s plenty to chew on – and again thanks everyone - Pete
