JThomas
Early in January 2022 I had a new 14000 gallon catchment tank installed on my property in Hawaii. When the installation was complete, I had 6000 gallons put in the tank. Heavy rainfall added enough added enough to bring it up to about 12000 gallons, enough to last 1200 days, if I do no irrigation (ten gallons usage per day, max). But no. by the middle of the month, we had no water available. The tank was found to be empty down to where the foot valve could not pick up water (6 inches). Two possibilities presented themselves: a leak in the tank liner or a leak in a pressure line. We put another 6000 gallons in the tank to check these out. With the pump on, we found no pressure line leaks. Plus, there was normal pressure at kitchen faucets, which there would not be if there was a bad pressure line leak.
With the pump turned off, the water level in the tank dropped from just over 30 inches down to about 18 inches, a rate of about 2000 gallons per 24 hour day. There it remained. The liner was examined at that water line by three different people and no damage was found. There was no sign of that much water leakage anywhere on the property. The ground at the perimeter of the tank remained dry at all times.
I'm hoping to find someone who has encountered a similar situation and who has found a solution.
