Hello,
I have pool feed line connected to a hose bib, I believe was not installed properly and therefor is corroded.
There is a copper pipe coming out of the wall and a galvanized (i think) tee connected to it with valves connected to the tee. Both valves and the vacuum breaker are corroded and leaking. Here are some images of the assembly:
https://drive.google.com/open?id=0B_PuNfI-toO0VHlxbFNFQ1NSSjctTzM1SnBzWjBlSk5odFdv
https://drive.google.com/open?id=0B_PuNfI-toO0S0RlX1Q4YzhOR3p1UDhES2o2YlRRTGdUbndn
I have a couple of questions:
1. Where do I even start to uninstall everything. Maybe a stupid question, but I don't see how to uninstall the tee...
2. What should I use to replace the assembly? (all brass, galvanized with bielectric connection?)
Thanks in advance for any help!
