globaltree
Hi all.
I have double sided Kohler porcelain coated cast iron under mount kitchen sink (salvaged) -- the kind with a narrow shallow sink on left, and wide deep sink on right -- beautifully installed under granite countertop; however, after four separate strainer baskets, and heaps of putty, it still leaks around the basket of the small side--I believe the contours of the drain hole are defective... Is there anything besides plumbers putty that is still loose enough to remove the baskets in future, but firm and tacky enough to fill the irregular shaped sink hole so it will stop leaking? Any and all advice is appreciated, as I have done this all myself, without any guidance...
