Any tips on how to fix or remove this broken tub diverter?
doubtfulAssumption
Jul 9, 2023
Los Angeles
The diverter is completely broken, so this is now a tub only (can't divert to shower head). Can't figure out how to replace or even remove this plate. The cap unscrews, but inside is just a hole about 6" deep that is too dark to see what's at the end of it. No idea what brand this is.
That’s most likely a tempress 2 rough valve.
There’s a Phillips or flathead screw at the bottom of the hole in the handle most likely.
Get a flashlight and look.
Many manufacturers used that rough valve. There’s a plastic piece on the diverter that has a tendency to break.
It could be several brands using that same Tempress 2 valve body. Many used it.
Your trim looks like it’s NewPort Brass or Plumbtrim. Same difference.
Thank you so much for the help.
You were spot on about Newport Brass. Amazing. I reached out to them and they identified it as a 3-822BP shower set and gave me some tips. Thank you so much!
