Your commercial kitchen faucets?????I hope our sinks don't have crossover issues, that would make things so much more complicated
All this time, every single crossover we've had in the hotel tower came from the shower pressure balancing units.
Is your commercial kitchen on the same
Riser......just thought of something else you must have a commercial laundry sometimes an electric solenoid valve can
Go bad,
Do you have soap injected washing machines, if so do you have testable backflow devices you would need rpz not double check devices
I don't think it's the shower valve it's just that the valve has the hot and cold connected it's like it's one pipe, one thing you could try is putting check valves on the hot and cold and see what happensYour commercial kitchen faucets?????
But that won't solve your issue there is something being overlooked. Go thru the posts, make a list check things we talked about check one thing at a tim e start simple
I think Jeff has the ''quickest'' way of finding your cross connection.Or maybe you could shoot an infrared thermometer at the hot and cold supply inlets.
While the stops are still open.
The valves that are passing would be different temp than the rest on the stack.
I know there alot of valves your working with so this can't happen again could you pick 1room and cut check valves in????I wonder if Kohler fixed the issue with the old style PBUs crossing over. The new ones look very different.
I understand that just figured you could try one rm and see if that cured the problem for that rm at least you would know that check valves would or would not helpIt would be a major remodel to access the copper lines and would have to do every single room
