I will keep this as brief as possible. I'm old (almost 74) and plumbed my whole house in 1981, and re-did the well in 2008 (shallow well jet in basement, only lifts about 5'). Everything has been fine since.
But I'm done doing this kind of thing; still physically able for the most part, but just don't want to. So I had a new electric water heater put in in October 2023 by some lame plumbers from Lowe's.
New well drilled in 2005 had gobs of iron in it, had a softener specifically made to remove iron installed in February 2006 by the local Culligan company -- everything went smoothly. It's worked great for years; had new beads put in in October 2022. But water is not quite as good as it used to be.
So in February this year I had the same Culligan company (huge mistake, different people) put in some type of filter ahead of the softener to address the iron.
So since then (I think) I've had air blasting out of the bathroom sink faucet in the morning. Not every morning but more than half the time. Sometimes a lot, sometimes a little, sometimes none. Might be after the new system regens (every 4 days) but not sure of that.
My well pump does not run randomly when I'm not using water so to me, that rules out a leaky foot valve or leaks in the suction line from the well to the pump which I'm assuming could draw air into the system. Is there any possible way I could be getting air in my system other than the new filtration contraption? They were here about 3 weeks ago to "fix" the problem but it didn't help. They are coming back tomorrow (Monday 5-13) to look at it again.
Is it at all possible it could be the water heater? (doesn't seem possible to me). Everything is constantly pressurized, obviously, no water leaks, so how can air get into it aside from the new filtration system?
