gozilla
hi there, i need to replace a shower drain that is leaking in a fiberglass pan. not sure exactly how to do it. most internet advice shows something where one unscrews the drain from the top side of the pan. there is no apparent way to unscrew my implementation from the top side of the pan. there is obviously a large threaded ring underneath, but it seems that maybe the whole unit was installed before the pan went in and then glued to ABS from below after the pan was installed as it would be very difficult to unscrew the ring under the pan from below. i've attached some pictures.
do i need to somehow try and cut the ring from below with an oscillating saw or dremel? or could i do this from the top?
any advice greatly appreciated.
