My friend currently has a wall-mount style showerhead with built-in slidebar. The controls are Delta Lahara dualstatic with a multichoice valve. It allows for control of both pressure and temperature.
He wants to change it out to have two ceiling mount rainshower heads as well as a handheld. I've seen setups where some sort of loop plumbing is done to make sure each showerhead gets equal pressure. I saw Amazon.com
It allows for 3 "shared" positions and 3 individual positions. I'm guessing that means more than one can be on at a time. It goes with the R11000 valve. If the showerheads are on separate ports of the valve (it has 3 outlets and one inlet). Let's say the rear/farther rainshowerhead comes out of the middle, closer showerhead comes from the left, and then handheld comes from the right. Would I need to do any looping to get equal pressure from the rainshowers? Or would the valve balance that out?
The part going to the handheld would be like this:
https://www.amazon.com/Delta-Faucet-50560-BL-Elbow-Shower/dp/B000KQ5XLK/
Might be able to find a cheaper one with similar look.
So, plan is something like this:
The pipes would go up into the ceiling and of course things would be spaced differently. This is not to scale.
Editing to add that there was a This Old House video that suggested going up to 3/4" pipe to increase pressure/flow. Would that work with pex if the line coming in to the room is only 1/2"?
Any thoughts/suggestions?
