gerkear
Ever since we purchased our house we've had a sporadic problem of our 1st floor toilet not completely flushing. This even occurs under minimal waste. I adjusted the chain and replaced the flapper but saw no results.
I recently went in the basement to inspect the toilet waste pipe which travels from the toilet roughly 5 feet to the main sewer stack. I put a 4 foot level on it only to find that the waste pipe between the toilet and stack is nearly level.
Can I adjust the level of the existing (glued) pvc to force in a slope or should I cut the pipe close to the stack and reinstall using pipe hangers to achieve a 1/4" per foot slope required? Both options would require some modifications at the toilet flange which I am aware of.
Any suggestions would be helpful. Thanks!
