Hi Guys,
I'm looking to add a 1/2 bath on the 1st floor. I'm thinking about doing the plumbing work myself but need some advice from the plumbing pros. I have included pictures and layouts on how I am thinking about running my drain lines. I plan on running the drains under the floor joists since I have heating and cooling duct work in between the joists. The other thing is I have a 8" thick brick wall that I am really trying to avoid drilling through (this is why I plan on running through the old window slot (see drawing). I plan on using ABS piping since that is the material of
Questions I have.
1. Does my drain plan look ok to an experienced plumber?
2. I plan on venting the toilet with the sink vent through the roof. Is this correct? Can I use an air admittance valve instead of going through the roof?
3. My toilet is going to be approx 15' from the main stack. Is this too far? All lines will slope 1/4" per 12" except when I get to the final connection in the main stack. The final connection will have a large slope on it. My main drain will not be in a straight line. It will need to go back through the wall opening to reach my main stack. This is to avoid drilling a 3" hole through my 8" brick wall.
4. My sink drain and sink vent is going to be 2" connecting into the 3" toilet drain.
5. Should I add any cleanouts? If so, where?
6. I have approx 11" vertical drop right after the toilet flange before it reaches the 1st 90. This is to avoid hitting my ducts. Is that ok?
7. Any suggestions on fittings, layout, venting? Anything, I'm all ears. Thanks in advance.
Questions I have.
