5000 gal storage tank filled to the max, need solution to lower the level
chaseme5
Active Member
Mar 11, 2012
34
Hi
The company that installed the well is not in business anymore.
The float switch is very short. Instead of being 10ft long, it is only
1 ft. long at the top of the tank. This does not seem right. The tank is full to capacity because of this.
What should I do?
pump it out and install a proper float would be the obvious solution, I recomend finding a plumber who specializes in this type of work and has a good reputation
There are very few plumbers if any out here that work on wells. How do I turn the pump off inside the well without cutting of the entire system off?
I would think that there would be a seperate control to turn off either pump.
But personally, to be on the safe side, I would shut down the power to both while working on either.
Always shut down all the power, and Even then, check with a meter to verify its off.
The system is not labeled. There is a pump motor drive. It controls the surface pump. If I disable the motor drive unit, the well pump still pumps water. If I cut the power, everything is disabled. I want to know what controls what. There is one control. It is a computer controller.
Is the well pump controlled on a seperate controller?
