Themachinist
1922 house.
2nd floor shower bay install without access from below. Hence leaked causing ceiling to leak. Big mess, now have an accessible 3' x 4' area to work in. New drain installed 3 weeks later small leak noticed 180 degrees from pvc pipe. With someone standing there noticed flexing. Drip is per 10 min 3 drips.
Thoughts are bracing up shower bay with shims and a low to no flex foam spray. Appears to need that. What you see here is before pvc replacement and drain.
What are your thoughts?
