Now the pins make sense. I assumed it was a older style of an orbital pad like on the end of a bar top stool.I have removed a few of those during kitchen remodels. They were usually in a historical district. If you look close at the bottom of the legs there are small pins that fit into holes drilled into the tile floor. Prevents leg from moving if accidently bumped. "Very Heavy" units.
Sink is cast iron and weighs 380 lbs.Is that sink cast iron or metal. About how heavy is it. That will look really nice with a new faucet
and shined up.
Jeff American standard was know as standard 100 years ago. later it became American standard, I have worked on many of those bathrooms and toilets , with the flush bend elbow, and upper and lower lift pins on the Douglas valve, Made a fortune fixing them.I had a client with an old bathroom with all that same color of fixtures, but I think it was all American Standard.
Approx 100 year old fixtures.
House was built in the 1860’s.
Seafoam green, I believe.
Very nice color, and popular now with the retro crowd.
There was also a super scary electric heater, literally just a few inches from the toilet.
Basically a toaster sitting inside the wall.
It still worked!
Well, we have one person who saw them, one person repairing/working on them....... for the trifecta, my father worked for American Standard, making toilets in New Orleans, when he was in college studying Ceramic Engineering about 1966-1967.Jeff American standard was know as standard 100 years ago. later it became American standard, I have worked on many of those bathrooms and toilets , with the flush bend elbow, and upper and lower lift pins on the Douglas valve, Made a fortune fixing them.
there is a trick, i used to use plumbers cotton wick , I tried to find it on the web but could not. it was a cotton string but not tightly woven . more like a wicking string. I used it like hemp around threads . we used to call it angel hair . It would swell when wet and stop all leaks. better than Teflon and dope. . very good on large threaded pipes like 3 - 4 inches .I use to hate working on those old wall hung toilets. The nuts and washers that you can get usually didn't
take care of any leaks. Got lucky on some though.
