Hello. This is caused by sloppy drywall work. Hole was cut too big. Is there any type of flat cover I can buy to fix the gap and cover the hole? I dont want to have to putty around hole. Please see pic and thank you for suggestions .
cut the plastic white escutcheon off of the pipe, then as SHR said, mud that hole up
with tape and drywall mud.
then, buy what is called a split ring escutcheon to snap together around the pipes
If you don't want to patch it try this.
get a square of vinyl and cut a hole in it. then make a cut from hole to edge.
slide it over the pipe and glue it to the wall.
