Valve on a vent pipe
Nov 9, 2023
16
MN
Hi
This is a dry vent. There is a valve on it. Should I make an accessible cut through dry wall?
Thank you.
That is not a valve. That is a test tee with a threaded cap. It can be used as a cleanout so I would definitely make it accessible. I would also plug the hole or get a new threaded cap.
That plug has female machine thread insert so a finished metal cover can be installed after the finished wall is installed.
It’s a wall cleanout.
Looks like the used silicone as pipe dope.
How do I plug it? And what’s wrong with existing cap?
I didn't look at the picture close enough. I saw the hole and assumed that someone had screwed a cover on with a sheet metal screw like is common in my area instead of getting a threaded plug like in the picture.
There's nothing wrong with the plug. I didn't look at the picture close enough
