Utility Tub Install / Drainage Question
nervine
Jan 27, 2018
Hi, I'm installing a utility tub right next to our washer and dryer. I want to be sure I'm taking the right approach when tapping into the plumbing for drainage. I've attached a picture of the existing plumbing. I'm thinking I should tap into the line just above T that goes to the bathroom in the other room. Is this correct? Is there a better spot in this configuration? Thanks!
Going above t looks like it might be to high for your sink I would go below to and also install a clean out
