For whatever reason, the hose drain for our washing machine that appears to of been built into the house was unused when we moved in. It appears that the previous owners, at some point, put a hole in the wall to put a drain hose through to the outside; Which after some distance lets out into the yard.
I have no real way to contact the prior owners to find out why this was done, but I'm sure there was some reason why they did this. If possible, I'd prefer to connect the drain hose into the original drain pipe and seal up that hole; also not letting the washer water into the yard. That being said, I have no idea how to verify if this pipe has issues, is clogged, etc. Not sure how I would verify that this pipe is useable.
