Situation:
The current toilet is a Kohler with a canister flush valve. It is only around 7 years old;
however, the customer is complaining that it is a poor flusher. My term, not theirs,
but you get the idea. I have been there a couple of times, have tried to make minor
adjustment as possible, have tested it multiple of times, and it all works as intended,
but there is still the customer complaint.
Fill valve - Is set to fill the tank to the top of the canister.
Flush Handle, trip lever arm, and chain all function as intended.
I.e. No hang ups and the canister is pulled up as high as possible.
Canister - Functions as intended and there is no leakage.
Water type - Municipal system without minerals.
I.e. it is not hard water, so there shouldn't be any calcium build up under the bowl rim.
At this point the customer wants a new toilet.
Question:
What are your recommendations for a replacement given your experience
for this same type of situation?
TYI
Question:
TYI
