This a good setup under the drain
RegualrGuy
Dec 28, 2023
5
California
This look good…??
Is it suppose to be separate pipes???
Or suppose to connect T-pipe than trap?
It drains slow…
As you have asked this question about the drain piping, I assume the slow draining condition has always been the case rather than something that just started.
But if this is just a recent occurrence, then is the slow draining from both sinks or just one side?
Is there a vent up to the vent stack inside the wall above those two connections? If not, those become S-traps which are illegal and can be prone to slow draining.
Just about always been the case.
And not sure about the vent…
I did not install..
Both sides. Fills up with like about a half gallon of water.
You could try plunging each side but that may not correct your problem.
After I used the plunger and if it doesn’t clear the problem, I’d use a 3/8” drain cable about 50’ long to cable the drain with.
Got the maintenance guy back here right now. He’s going to snake it (again) and see what happens. He used a small snake last time. Those hand crank ones probably like 20feet at most.
Crazy it only takes like half a gallon to start to back up above the drain.
