Jack.Straw
Hi guys. We have this double sink in our kitchen. About every 2-3 months I have to take the thing apart and clean it out because sludge builds up and starts to stink up the kitchen. I've tried things like Draino, but that doesn't seem to do the trick, so I just keep taking the whole thing apart, blasting out the build-up outside with a hose, and using a big bottle brush with bleach in the slop sink to remove the rest and kill the bacteria. I hate doing this and would like to find an actual solution.
When I look at the way the contractor installed the pipes, it occurs to me that maybe this is happening because there is no tilt/angle to the pipe coming from the left sink. That is where the sludge build-up happens. Is the solution to add a peice below the right sink to drop down the trap and create a slope coming from the left sink drain, and then add the same size peice back behind the trap to bring the pipe that goes into the wall back up to level with the opening? Or, is there a product that I can use that will actually remove the sludge and smell? Thank you for any advice you can offer.
