Slow draining cast iron tub with old style cleanout
aphex732
Mar 16, 2018
I have an old cast iron tub that fills up with water and drains very slowly when the shower is on. It has an old style cleanout outside the tub as shown in these pictures:
https://imgur.com/a/1U0qm
When the cleanout is in the fully closed, normal position the tub does not drain. As soon as I open the cleanout, the water rushes out and the tub drains perfectly.
Is this an issue with a clogged vent pipe? The sink and the toilet in the bathroom seem to work perfectly and drain/fill without issue. If it is, what's the best way to fix?
Thanks for your help!
so, when its partially pulled up it works fine and when it sits fully down it doesn't drain.....????? if that's what your saying i think its working fine like you said if the vent tht bathe was clogged all fixtures would be effected
just think of it like the pop up in your sink
