I finished a day or two after Christmas .
Rented a Kubota mini-excavator at Home Depot to dig the ditch .
I had pre-purchased all the parts and pieces ahead of time . Turned out the 1" PEX and 2 barbed brass fittings were SharkBite , after all .
Well , the place I rented the crimp tool , the tool did not go up to 1" . Ended up buying the SharkBite tool for 1" on down , for a little over $ 100 . To make 2 crimps ( with the black copper crimp rings ) .
I used the white 1" SharkBite from Home Depot . Was cold & WOW ! Is that stuff ever STIFF ! And it has one heck of a memory from being in that 100' coil ! :-(
I had to walk it down / into the ditch , using a hoe to drag dirt down on top of it . To get it to stay down into the ditch ! :-(
But , now that it is in the ditch & covered up , all seems to be well .
One crimp is at the meter , with the barb attached to the meter fitting with a brass 3/4" x 1" reducing bushing . The other is under the house , with the barb screwed into a ball valve , where I have connected it into the 3/4" copper cold water line .
I hope to not have to cut another ditch for a long time . And not to have to crawl under the house , again for a while .
Rightly or wrongly , I probably would not have trusted the push fit fitting at the water meter . Certainly not under the house , out of sight and mind .
And , I am told , if it ever does freeze ( I do not think it will ) , that the PEX is suppose to expand and not bust .
Other than that , PVC would have worked & I would not have had to buy the crimp tool . But , truth to tell , the ditch was the most $$$ part of the project . A little less than $ 300 for 24 hours to cut the ditch and a little less than $ 200 to rent it again to cover the ditch back up .
I still need to do some shoveling and raking ( hoe ) to level and fill .
Thanks for the help !
God bless
Wyr
Happy New Year
