I have a concrete tank which leaks from underneath the lid. Basically what is happening is that whenever water goes down the drain, a stream of water flows out of the tank. The water coming from the tank doesn't smell and there are no other problems with the plumbing inside, nor is there any saturation on other parts of the ground.
Will a simple pumping fix the leak? Could it be worse?
